Slow button navigation event response
Thank you for your advice.
Now it works. But the tabs are not clickable when the program is in "Run mode".
Message 11 of 12
(604 Views)
That is expected. For the tab to be clickable, it needs to be a control. Currently it is an indicator.
Indicators can (for obvious reasons!) not be operated at run time. You can easily change that with a few simple modifications to the program. Since you also want programmatic control, you might need a local variable. No big deal. 😉
Message 12 of 12
(599 Views)
