Slow file writing with CompactRIO
I am running 100Hz control application with LV8.2 on CompactRIO.  I need to record certain variables, about 70 bytes per loop (per 10ms), so I put the file-write vi inside the loop.  I'm writing to the flash memory in cRIO, figuring that to be the fastest method.  Since the file-write vi is inside the loop, I'm thinking that it will actually write each loop.  But what seems to happen in reality is that it puts the data in a buffer and writes it once per second.  Here's why I think that:  My control loop hums along with 10ms loops for one second, then at the end of each second, one loop will take 30, 40, even 120ms.  If I leave everything else intact and take out the file-write, the once-a-second hiccups go away.
I'm thinking that writing the file on the host via TCP/IP would slow things down even more, judging by how much a few real-time indicators on my laptop screen will slow down a vi.
You might suggest separating things into a time-critical (deterministic) and non-deterministic loop.  Would that help, though, if the thing insists on writing the entire file once a second anyway?  Why won't it just write 70 bytes per loop like I ask instead of saving up 7000 bytes to write at once?
I open and close the file outside the loop (i.e., only at program start up and stop, not each loop).  I've tried both text and binary files; the binary files go somewhat faster but don't make the problem go away.
(2,932 Views)
I don't have much experience writing to files on RT platforms, but I wonder if the Flush primitive in the Advanced File Functions palette could help.
(2,930 Views)
