Slow graph update with NaN values
I was playing with waveform graph (update via property node) and found out that it takes much longer when plotting data with NaN values compared to plotting data with no NaN values (see attached example). Is this expected behavior?
Message 1 of 15
(4,291 Views)
Please post the code in 2011 version.
Message 2 of 15
(4,286 Views)
Is the NaN data replacing real data, or is it in addition to the real data?
nvm - I answered my own q by looking at the code.  😉
Bill
CLD
(Mid-Level minion.)
Message 3 of 15
(4,280 Views)
Actually, I see no difference in the times.
Bill
CLD
(Mid-Level minion.)
Message 4 of 15
(4,278 Views)
While benchmarking (against execution time) I prefer to run the code in a For loop and then take average. I don't see much difference also the results are quite inconsistent, probably because the target is Windows.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 5 of 15
(4,275 Views)
However, if i connect the data directly to the indicator, instead of to the property node, the value drops to ~ 0 ms for either...
Bill
CLD
(Mid-Level minion.)
Message 6 of 15
(4,274 Views)
Passing data using wire should always be first choice...!!
Message 7 of 15
(4,271 Views)
Hmmmm interesting. If I run with "No NaN values", the average time is around 24 ± 1 ms, while with "NaN values", the average time is 435 ± 5 ms. So results are quite different and consistent for me.
I'm aware that local variable and terminal will make it faster.
Message 8 of 15
(4,265 Views)
Maybe you are demonstrating why it is so much better to wire data directly to an indicator, rather than to a property node.  😉
Bill
CLD
(Mid-Level minion.)
Message 9 of 15
(4,260 Views)
Even I got the same result but by wiring to the terminal no difference among both. I wonder it depends on the OS also (Smiley Indifferent)
Message 10 of 15
(4,252 Views)
