Slow scrolling with a mulitcolumn listbox
Thanks in advance for any help everyone!
The scroll rate of my multicolumn listbox is painfully slow when I scroll using the arrows of the scrollbar.  This is only the case when "smooth scrolling" is enabled.  Dragging the scrollbar itself works fine.  I've attached a VI to this post that demonstrates what I'm talking about.  Any solution/advice would be greatly appreciated.
Tom
(3,493 Views)
You can read the context help to see why this is happening.
If you leave it to false, is this a problem ?
(3,474 Views)
Anyone?  This is still a major issue with my user interface.
(3,410 Views)
Pnt is right. This behavior is documented in the context help for the property node.
The problem is that each click of the mouse on the arrow keys is only scrolling by a single pixel. This will have the effect of a smooth scroll, but will also cause the scroll to take much much longer due to the one pixel increment. Setting this property to false will speed up the scrolling because a single column is now your scroll increment.
Message Edited by Captain Kirby on 10-14-2008 10:43 AM
Asa Kirby
CompactRIO Product Marketing Manager
________________
Sail Fast!
(3,397 Views)
I am aware of the effect of SmoothHScroll.  Please refer to the example VI I created and attached to my original post.
Perhaps I should clarify my question:  Is there a way to increase the arrows' scroll speed when smooth scrolling is enabled?
(3,347 Views)
As far as i know, no
(3,334 Views)
