Slow to configure multiple USB3 Cameras
I'm using the IMAQdx drivers to run 4 USB 3.0 cameras on my system. The issue I want to resolve is that when I open and configure the cameras for grabbing, the 3rd and 4th camera take a long time (~10 sec) while the first two take less than 1 sec. I knew I wouldn't be able to get full frame rates (~40 fps) out of them, which is fine, I only wanted ~10 fps. Once they get streaming, everything is good, but I don't want the user to have to wait 20 seconds for the application to initialize. I only see this behavior in LabVIEW using the IMAQdx drivers. If I switch back to the vendor's driver and use their software, the cameras start up in under 1 second.
The cameras are Basler Ace cameras, and the USB ports are using the Rosewill RC-508 USB 3.0 to PCIe adapter.
Thank you for any suggestions!
(2,533 Views)
Have you tried using different USB ports? Are they all going through the same adapter? Are they all the same camera?
(2,501 Views)
I am using a 4-port PCIe adapter which all 4 cameras are plugged in to. I don't think this is an issue, because when I use the Basler software, all the cameras start up quickly. There are 2 cameras of one model, 2 cameras of another model, all from Basler. The models are acA1920-40um and acA2040-55um. It doesn't matter if I start up 2 of the same model, or alternate models, the first 2 cameras to start up (open and configure grab VIs) take less than 1 sec, while the next 2 take ~10-20 sec each.
(2,494 Views)
