Slowdown of FIFOs when performing multiple cRIO simulations - are FIFOs not reentrant?
I am simulating multiple cRIO chassis on a single multi-core machine, and have come across a problem with the FPGA FIFOs. A single simulation works fine, but when I have several simulations running in parallel, the FIFOs are considerably slower. I've put together a very simple example that demonstrates this, see attached. It seems like the FIFO is not re-entrant. Is there a way to change this behavior? My goal is to have a large number of simulations running, but I am currently limited to just 2 or 3 due to this FIFO slowdown. Any help would be appreciated. Thanks.
(2,138 Views)
Hi Chris,
Thanks for taking the time to make an example project that clearly shows the problem you are seeing. When running on single mode, I see that the delay stays at around 30 ticks. When the Main vi is run on "Multi", I see a spike at the beginning, followed by a return to the delay levels we see for just one DMA FIFO. Because I was curious, I changed the delay in the FIFO_Read subVI to various ms values to see if it affected the average delay.
Here were my results:
Wait function (ms), Average delay (ticks), Multi spike (ticks)
1000, 50, 2000
500, 30, 2200
200, 20, 1200-2300
100, 10, 1500
Is this the performance that you are seeing as well? I noted that at some points my CPU utilization would spike to 40%. It seems like after the initial spike, the simulated Multi-target DMA FIFOs are able to run at a speed similar to a single target. Also, what version of LabVIEW/RT/FPGA do you have installed?
Joey S.
Senior Product Manager, Software
(2,108 Views)
