Slower frame rate than expected in acquisiton using cameralink
I'm using NI 1427 cameralink card to acquire and save images with CCAM cmos camera.
Using ROI I can increase the camera frame rate up to hunderds frames per second (FPS).
When I use the IMAQ sequence.vi to acquire a sequence of frames, the resulted FPS is much less than expected (i.e. 230 instead of 370). I'm using a flat sequnce structure with 2 clocks to estimate the acquired FPS.
When openning the camera in MAX I checked that indeed the camera works at the high FPS.
I'm working on PC with AMD Athlon64 x2 Dual 3800+, windows xp pro, 1Gb RAM, Labview7.1.1, vision acq. software 8.2.1
Can anyone spot the problem?
thanks
Omer
(2,720 Views)
Omer,
I can't see anything readily from what you just described.  Can you post the code so that we can see if it is something in software that is causing the slowdown?
Luke H
(2,706 Views)
Hi Luke, thank you for your response.
I attached the sub-vi I'm using.
Omer
(2,693 Views)
Omer,
Another discussion thread is open discussing this issue on the Machine Vision forum.  A link can be found here.
(2,678 Views)
