07-17-2006 04:24 PM
1) Regarding continously adding a string or array. Yes, I may be generating a log report after each test on product. I will remove that and see. Couple of more things I want to clear up based on the *.pdf.
2) Third party (IOTech) had supported me good. They are also working on this problem since last two months. They changed me the lower version board with higher version and fixed their memory leak problems (thats what they says) but still when I start the application Labview shows 32-40K in task manager. After an hour or so, it shows 190,000 KB or so. So definately it is going to hang.
They released new version of third party software support based on the investigations.
Thanks.
07-17-2006 04:34 PM
07-18-2006 05:51 PM
07-18-2006 06:15 PM
I am able to install programs which uses Installshield or their own installer. But including LABVIEW runtime engine, which uses Windows installer are not getting installed. I am getting error of service could not be accessed or windows is running in safe mode. I searched for services and found that Windows installer is running. I also updated the installer with new available installer configuration for XP2. But still installation error. How to find window is running is safe mode or not?
Thanks.
07-19-2006 04:16 PM
