Small Fonts not Available in Icon Editor
Hi all, I just installed LabVIEW on a new laptop, and I cannot use Small Fonts in the icon editor. I've tried to install the font file, and I can see it in "C:\windows\fonts". However, in LabVIEW when I type text into the icon editor, it's still using several colors to try to make a black font. If I select a different font, I cannot get back to Small Fonts because it's not in the dropdown menu. (I have to edit the ini file). Any suggestions?
Using: LabVIEW 2016 (32-bit), Windows 10 (64-bit)
Message 1 of 9
(3,517 Views)
Message 2 of 9
(3,512 Views)
Hi Wiebe, thank you for the suggestion. I added "FontCodePageList" to the ini file and modified the region settings, but no change. Also, even when I make the font larger (bigger than 11) it's still not monochrome black.
Message 3 of 9
(3,488 Views)
Edit: I totally misunderstood the question.
Bill
CLD
(Mid-Level minion.)
Message 4 of 9
(3,468 Views)
I reinstalled the Small Fonts file from another PC at work. Previously I got the file from a forums post. I also ran the NI updates.
Now I can use Small Fonts in the icon editor! But, if I switch to another font I cannot get back to it. I have to go into the .ini file and set:
IconEditor.TextTab.TextFont="Small Fonts"
Still kind of annoying, but at least it's workable now.
Message 5 of 9
(3,409 Views)
Same problem now with LV2020. Few versions ago I have copied Small Fonts from older PC and it works. It seems I have to do this once more as only I will find an old PC with LV.
Message 6 of 9
(3,086 Views)
Hej, did you solved this problem? For me seems like nothing happens.
I tried to reinstall Small Fonts, edit config, chang region, but I sill can't use Small Fonts in Icon Editor.
LV2020
Message 7 of 9
(2,184 Views)
Just don't use text in your icons.
Message 8 of 9
(2,160 Views)
I solved it finaly. I download Fonts Pack for Win10 from this link, https://www.w7df.com, and tried several Small Fonts from the pack.
Hope one of this Fonts will help.
Message 9 of 9
(1,875 Views)
