Small fonts for icon
I had to reinstall LabVIEW on my computer.  The code I previously did used "small fonts", size 8 for the text in the icons.  Now this font with the same version of LabVIEW 7.1 disapeared.  Why that?  Where does this font came from?
Thanks!
Patrick.
(3,980 Views)
Patrick,
To change the font size of text created in the icon editor, all you have to do is double-click on the font tool in the icon editor window and change the size inside of the attribute box that pops up.
Kind Regards,
E. Sulzer
(3,938 Views)
that's the problem I have!  When I double click on the font tool in the icon editor, the font I used to have before (Small Font) is not in that list anymore.
Patrick.
(3,911 Views)
Patrick,
That's very strange! One thing you can try to do is to set the default font manually even though the desired font doesn't appear in the font list. Open up the LabVIEW.ini file in Notepad (located in the same directory as LabVIEW.exe) and add the following line to the file: "IconFont="Small Fonts" 8" (exclude the outer quotes). Save the file and restart LabVIEW. If this doesn't work, then I can only assume that this is some minor corruption in LabVIEW, so if its important you, you can try uninstalling/reinstalling LabVIEW to see if that fixes your problem. Please let us know how it turns out so that others who encounter this problem will have some help!
Kind Regards,
E. Sulzer
(3,897 Views)
Great!  That works.  When I type new text in an icon, it's using Small Fonts 8.  If I double click on the text tool font, I can see Small Fonts in the Font list.  However, if I click on that list, Small Fonts is not in the list.  Anyway, that's ok for me this way!  Thanks!
(3,889 Views)
