Smaller Version of Variant to Data
Hi, did anyone create a smaller icon version of LabVIEW's Variant to Data ?
I think it takes way too much space.
Actor Framework
Message 1 of 10
(2,164 Views)
You can do it yourself if you make a *.VIM file and put nothing but the "Variant to Data" VI in there, then make the icon smaller than the standard 32x32 and select a connection pane that works with your smaller icon.  Look up "Malleable VIs" or VIMs if you don't know what I mean by that.
It's not that big of an icon though to worry that much about reducing it, and VIM's aren't perfect.  It may create more problems that it solves.
Message 2 of 10
(2,143 Views)
I like the size because the input is perfectly aligned with the vast majority of the connector panes of anything I wire to it.
Bill
CLD
(Mid-Level minion.)
Message 3 of 10
(2,132 Views)
Accepted by topic author Quiztus2
Message 4 of 10
(2,069 Views)
This is so nice, I thought I would need a Polymorphic SubVI for alle the different possible type inputs. Your version is so much better.
Actor Framework
Message 5 of 10
(2,057 Views)
Just remember that VIMs have their own set of problems.  Just make sure you're not causing more issues than you're solving.  A cosmetic fix just isn't worth creating potential pitfalls in your code.
Bill
CLD
(Mid-Level minion.)
Message 6 of 10
(2,037 Views)
Gee, I was being sarcastic, making the icon as small as I could.
Message 7 of 10
(2,030 Views)
Sarcastic only about the size or also about using .vim here?
Actor Framework
Message 8 of 10
(2,008 Views)
Just the size.  I don't have a problem with malleable VIs (though they can be quirky at times).
Message 9 of 10
(1,972 Views)
That's what I mean.  Is this "quirkiness" worth the cosmetic fix?
Bill
CLD
(Mid-Level minion.)
Message 10 of 10
(1,954 Views)
