Smart lighting control system using labview and arduino
Hi,I am a new engineer and working on a project of home automation using labview and arduino.I want to control the turning on and off of bulb and lamps in my house model when it sense a movement any movement (smart lighting system) and control the on off through Labview.I am a new user of LabView.How can I make a block diagram of lighting control system and interface arduino with Labview?
Never feel ashamed of learning something from others
Message 1 of 12
(7,644 Views)
You need to play with little hardware also. First of all you need to find a solution to interface movement sensor to arduino. This is as per your requirement. I am sure there is lots of option readily available. Google it. Then you can use output of light sensor to turn ON/OFF light using relay.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 12
(7,628 Views)
Yes will do that.How can I make a front panel in LabView showing on off button and monitoring of the lighting system?
Message 3 of 12
(7,606 Views)
there is ON/OFF switch to show whether light is on/off in front panel.
What is the output of sensor
--Ranjeet
Message 4 of 12
(7,589 Views)
Message 5 of 12
(7,580 Views)
I haven't completed it.I am stuck with the labview circuit
Message 6 of 12
(7,561 Views)
What labview circuit?
--Ranjeet
Message 7 of 12
(7,558 Views)
oops! block diagram
Message 8 of 12
(7,545 Views)
you are stuck means that you tried somthing. It is better to show us what you tried so far.
and do not ignore the basic courses.
Message 9 of 12
(7,535 Views)
So what have you done?
Have you taken any of the basic tutorials ?
Message 10 of 12
(7,530 Views)
