Smearing in text indicators when mouse scrolling (broken redraw?)
@aputman wrote:
For the indicator to redraw with the scrollbars but not with the mouse seems to indicate that it is not a driver issue.  However, it wouldn't hurt to make these changes and see what happens.
Are any of those experiencing the issue running Labview on a laptop?
My posit was that anything to do with failed redraws is usually due to some kind of incompatibility with a video driver.  I know that my mouse driver differentiates between using the scroll bar and using the wheel.  Something about "smooth scrolling".  I venture to say that, depending on this setting, it uses accelerated graphics or standard scrolling to accomplish the task.
Bill
CLD
(Mid-Level minion.)
Message 11 of 24
(2,198 Views)
Hi all,
I'm seeing the "smeary" behavior when scrolling on the string control vertical scrollbar using the mouse wheel. As mentioned, when clicking on the arrows on the scroll bar, the text isn't smeared.
However this behavior isn't seen when the text cursor is placed inside of the string control and then the mouse wheel is used.
Also a clarifying statement,  the structure included in the Smeary string.vi is a string control not a string indicator. After wiring a string indicator to your control in the VI, the text isn't smeared when scrolling on the indicator. This smeared text behavior is only observed with the string control.
Alex
Hardware Engineer
Message 12 of 24
(2,167 Views)
@algarcia wrote:
Hi all,
That was everything except a CAR#.
Could you please provide a CAR# ?
Ben
Message 13 of 24
(2,162 Views)
An update. I went back and checked my case.
  1. It was a string indicator, not a control.
  2. It had a transparent background.
  3. When I changed the background from transparent to a color, the smearing stopped.
The transparent background seems to be linked to the problem.
mcduff
Message 14 of 24
(2,147 Views)
Hi all,
The information has been passed onto R&D, and they'll look into resolving the issue for a future version of LabVIEW.
CAR#: 660883
Alex
Hardware Engineer
Message 15 of 24
(2,136 Views)
This has been a problem for a while.
https://forums.ni.com/t5/LabVIEW/String-indicator-vertical-scroll-bar-BUG/m-p/2539204
Tim Elsey
Certified LabVIEW Architect
Message 16 of 24
(2,106 Views)
Hard to have hope for a fix when the bug is 5 years old.
Message 17 of 24
(2,093 Views)
Make a case for why it should be a high priority and hope is a little easier.
Ben
Message 18 of 24
(2,086 Views)
Why has this bug not been fixed yet? So sad....
For my application, coloring the string indicator the same color as the panel is not a fix because I am using a gradient as the background.
Also some people in this thread said that the smearing only happens for controls but not indicators or only for classic but not modern. But I have tried it with all of these and still see the smearing behavior on scroll wheel.
Sigh, I guess I'm just complaining, but does anyone have any ideas of other work arounds?
Message 19 of 24
(1,850 Views)
You didn't say what version of LabVIEW you were using but I just tried it on 2018 and it's still bugged.  It seems linked to the mouse hover feature so if you select "On Key Focus" on the Key Nav page of its properties it will scroll without glitching BUT you have to click in the window (or TAB to it) to bring it in focus first.
EDIT:  Just checked with the rest of the string controls and they all do it too, even NXG.  I can't believe I never noticed this before if it's that old an issue.  Even more strangely, the bug has turned the text into some kind of latin-like, alien language about some guy named Lorem Ipsum! Smiley Surprised
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 20 of 24
(1,834 Views)
