Smooth vertical scroll in a multicolumn listbox
Hi all,
I want to scroll inside a single column of a multicolumn listbox. This seems to be not possible so I have no chance to see the content of the end of a line if the listbox is smaller then the column height.
Is there a property node like "smooth horizontal scrolling" for the vertical position or any other solution?
Best wishes, Helmut
P.S. still using LabView 8.5
(2,752 Views)
Not as I recall in V8.5. Newer versions simply have a Smooth Scrolling property, with no mention of direction.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,737 Views)
Thanks for the fast answer - unfortunately that what I expected ....
Best wishes, Helmut
(2,728 Views)
