Snd Write Waveform.vi not run on Suse platform
in lvsound.so, VI 'Snd Write Waveform.vi'
Configuration : LabVIEW 7.0
OS : Suse 9.3
Alsa v 1.0.8 and 1.0.9
This function makes LabVIEW to exit!
It works perfectly with RedHad 9.0, XP and MacOSX
The behaviour is different between source and executable :
- source : no trouble before executing this VI
- exe : the main application loads and runs as expected.
As soon as it launches a subpanel calling this subVI it makes LabVIEW to quit.
(2,553 Views)
I have reproduced this problem and have been trying to figure it out for
a few hours now. It seems to happen on LabVIEW 7.0 only for SuSE 9.2
and 9.3 (both kernel 2.6 based), when running the SO Config.vi.
I have something for you to try. Please replace the file lvsound.so in
the LabVIEW resource directory (usually /usr/local/lv70/resource) with
the attached version.
On my system, this avoids the crash, which appeared to be caused by a
problem in the system pthread library trying to unwind the stack during
pthread exit. (The sound library uses threads to asynchronously
read/write data to the sound device.)
Regards
David D.
AE - NI France
(2,532 Views)
