Snoop the RS-232
johnsold wrote:
What does the motor controller send back?  How does that compare between the LV program and the manufacturer's software?
Lynn
That is a good question Lynn.
Does the device only receive?
Ben
Message 11 of 13
(986 Views)
The device sends stuff back when you invoke the "Verify" command (@0V<command>[profile]).  The device also writes back when errors are requested with the @0! command.  I've bolded the rows where the device wrote back to me:
0.00115294    DAQ and Control    IRP_MJ_WRITE    Serial2    SUCCESS    Length 5: @0VN1
0.00000223    DAQ and Control    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00092889    DAQ and Control    IRP_MJ_WRITE    Serial2    SUCCESS    Length 1: .
0.00000363    DAQ and Control    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00000196    DAQ and Control    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00000168    DAQ and Control    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00000559    DAQ and Control    IRP_MJ_READ    Serial2    SUCCESS    Length 5: 8890.
0.00000503    DAQ and Control    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00072691    DAQ and Control    IRP_MJ_WRITE    Serial2    SUCCESS    Length 9: @0T1_4444
0.00093867    DAQ and Control    IRP_MJ_WRITE    Serial2    SUCCESS    Length 1: .
0.00000782    DAQ and Control    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00097917    DAQ and Control    IRP_MJ_WRITE    Serial2    SUCCESS    Length 5: @0VT1
0.00000251    DAQ and Control    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00094481    DAQ and Control    IRP_MJ_WRITE    Serial2    SUCCESS    Length 1: .
0.00000643    DAQ and Control    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00000587    DAQ and Control    IRP_MJ_READ    Serial2    SUCCESS    Length 5: 4444.
@smercurio_fc - I see.  I'm tempted to try sending 1 char at a time just to see if it clears up my error flag happening during normal operation.  I also agree that it shouldn't matter, but something about the way I'm writing to the motor is causing it to throw an error flag at me about an invalid command and I am simply not seeing it.  Functionality is fine.  My program works just fine, except I have to ignore errors from the motor (which is undesirable).  I'm about out of time I can spend on this though ><.
Message 12 of 13
(966 Views)
Their software sending and receiving the same command:
0.00085123    SMPG-SMSI Softw    IRP_MJ_WRITE    Serial2    SUCCESS    Length 1: V
0.00000279    SMPG-SMSI Softw    IOCTL_SERIAL_SET_WAIT_MASK    Serial2    SUCCESS    Mask: RXCHAR TXEMPTY CTS DSR RLSD BRK ERR RING
0.00078278    SMPG-SMSI Softw    IOCTL_SERIAL_WAIT_ON_MASK    Serial2    SUCCESS
0.00000196    SMPG-SMSI Softw    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00000168    SMPG-SMSI Softw    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00000196    SMPG-SMSI Softw    IOCTL_SERIAL_GET_PROPERTIES    Serial2    SUCCESS
0.00088559    SMPG-SMSI Softw    IRP_MJ_WRITE    Serial2    SUCCESS    Length 1: N
0.00000251    SMPG-SMSI Softw    IOCTL_SERIAL_SET_WAIT_MASK    Serial2    SUCCESS    Mask: RXCHAR TXEMPTY CTS DSR RLSD BRK ERR RING
0.00082217    SMPG-SMSI Softw    IOCTL_SERIAL_WAIT_ON_MASK    Serial2    SUCCESS
0.00000503    SMPG-SMSI Softw    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00000168    SMPG-SMSI Softw    IOCTL_SERIAL_GET_PROPERTIES    Serial2    SUCCESS
0.00079451    SMPG-SMSI Softw    IRP_MJ_WRITE    Serial2    SUCCESS    Length 1: 1
0.00000307    SMPG-SMSI Softw    IOCTL_SERIAL_SET_WAIT_MASK    Serial2    SUCCESS    Mask: RXCHAR TXEMPTY CTS DSR RLSD BRK ERR RING
0.00072914    SMPG-SMSI Softw    IOCTL_SERIAL_WAIT_ON_MASK    Serial2    SUCCESS
0.00000279    SMPG-SMSI Softw    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00089592    SMPG-SMSI Softw    IRP_MJ_WRITE    Serial2    SUCCESS    Length 1: .
0.00083670    SMPG-SMSI Softw    IOCTL_SERIAL_WAIT_ON_MASK    Serial2    SUCCESS
0.00000335    SMPG-SMSI Softw    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00000223    SMPG-SMSI Softw    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00000363    SMPG-SMSI Softw    IOCTL_SERIAL_SET_WAIT_MASK    Serial2    SUCCESS    Mask: RXCHAR TXEMPTY CTS DSR RLSD BRK ERR RING
0.00262547    SMPG-SMSI Softw    IOCTL_SERIAL_WAIT_ON_MASK    Serial2    SUCCESS
0.00000307    SMPG-SMSI Softw    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00000670    SMPG-SMSI Softw    IOCTL_SERIAL_SET_WAIT_MASK    Serial2    SUCCESS    Mask: RXCHAR TXEMPTY CTS DSR RLSD BRK ERR RING
0.00084257    SMPG-SMSI Softw    IOCTL_SERIAL_WAIT_ON_MASK    Serial2    SUCCESS
0.00000335    SMPG-SMSI Softw    IOCTL_SERIAL_SET_WAIT_MASK    Serial2    SUCCESS    Mask: RXCHAR TXEMPTY CTS DSR RLSD BRK ERR RING
0.00000363    SMPG-SMSI Softw    IOCTL_SERIAL_WAIT_ON_MASK    Serial2    SUCCESS
0.00000196    SMPG-SMSI Softw    IOCTL_SERIAL_SET_WAIT_MASK    Serial2    SUCCESS    Mask: RXCHAR TXEMPTY CTS DSR RLSD BRK ERR RING
0.00089620    SMPG-SMSI Softw    IOCTL_SERIAL_WAIT_ON_MASK    Serial2    SUCCESS
0.00000475    SMPG-SMSI Softw    IOCTL_SERIAL_SET_WAIT_MASK    Serial2    SUCCESS    Mask: RXCHAR TXEMPTY CTS DSR RLSD BRK ERR RING
0.08394195    SMPG-SMSI Softw    IOCTL_SERIAL_WAIT_ON_MASK    Serial2    SUCCESS
0.00000810    SMPG-SMSI Softw    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00001006    SMPG-SMSI Softw    IOCTL_SERIAL_GET_COMMSTATUS    Serial2    SUCCESS
0.00000754    SMPG-SMSI Softw    IRP_MJ_READ    Serial2    SUCCESS    Length 5: 8890.
I think I'm going to send them an email and ask them if there is a reason they send 1 character at a time to the device.
Message 13 of 13
(963 Views)
