Socket communications in Labview
I'm developing an application in Labview 6.1 which will make extensive use of the Labview DSC.
This application will run on a Windows 98 based computer and, due to the nature of it, it will need to communicate with another application - which isn't a Labview based application - which runs on a Linux based machine. Since this Linux application can communicate with other ones using sockets - a socket server running on it and clients running elsewhere - I need to how I can use sockets in Labview to solve my problem.
Any help would be deeply appreciated.
(4,365 Views)
The socket functions are in the function palette under Communication->TCP.
With "Find Examples" you will find it under Networking->TCP&UDP.
As client you need "TCP Open Connection" to connet to the server and "TCP Read" and "TCP Write" to exchange data. At the end use "TCP Close Connection" to disconnect.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(4,365 Views)
Thanks Waldemar,
I'm going to try it right now !
(4,365 Views)
