Soft Front Panel PXI-5122 and RealTime
Can anyone tell me if the PXI 5122 Digitizer has a Soft Front Panel that is supported in LabView Realtime (8.6).
When I load the one that is on my system, it doesn't recognize my external pxi chassis hardware.
Thanks.
(2,721 Views)
The soft front panel that ships with the 5122 works only under Windows with devices directly accessible from Windows.  Since RT is a separate OS running over a network, the SFP will not work with it.  It could be modified to do this, however.  I will pass your suggestion on.  You may want to consider entering a product suggestion yourself (use this link).  Strange as it may seem, suggestions from customers are weighted more highly than suggestions from internal engineers ;).
(2,700 Views)
The Test Panel for the 5122 in MAX will work for remote devices.  This will provide some simple interactive and debugging functionality.
A more fully-featured interactive experience can be found using the niScope EX Configured Acquisition VI.  This is an example that ships with NI-SCOPE and can be used on a remote device in LabVIEW RT.
(2,622 Views)
