Soft Motion Error occuring when atempting to stop of signal
I'm having an issue when trying to stop a motion on signal coming from my crio. Everything (the movement) acutally works fine, but the error handler issues an error: -70225 Straight-Line-Move when executing 'Start' on Coordinate Space Real at Invoke Node in nimc.waitUntilDone.straightLineMove.vi.
I tried including "Wait Until Done" after the move but had not success.
Thanks for your help!
(988 Views)
Have a look here:
https://zone.ni.com/reference/en-XX/help/372134F-01/ni-motion_vi_help/error_codes/
"-70225" - NIMC_moveStoppedBecauseLimitOrHomeActiveError
"The move stopped because an axis encountered a limit, home switch, or software limit."
Perhaps you're tripping a limit/home switch when you stop your move?  I would try disabling the limit switches within SoftMotion first.  You can find the Axis Configuration page from the Project Explorer window, right-click Axis and select Properties from the shortcut menu to display this dialog box.  Check here for details: https://zone.ni.com/reference/en-XX/help/371093W-01/nimclvfb/dt/eng/generated/axisconfig_db/
(943 Views)
