Software List - NI Apps
Hi all,  I am the lead analyst for our factories windows 10 upgrade project.  At present we are auditing all our applications to ascertain what we have on various machines and what software is installed.  We will then look to see if that software is compatible with Windows 10 or if there is a upgrade path we can choose.  We have over 4000 machines between our 5 factories worldwide that are part of this project within our region.
I am not familiar with the NI software but I have a list of the NI software that is installed on one machine.  As with most software different components are installed as part of a main application install.  Can you spare some time to look at the list below of these NI installs and tell me what actual software it is that is installed as I know they come bundled in as they are not all separate installs.
Thanks for your help.
National Instruments Software National Instruments 0
NI .NET Framework 4.0 National Instruments 4.1
NI ActiveX Container National Instruments 14
NI AFW Channel Configuration Tool National Instruments 14
NI AFW Custom UI National Instruments 14
NI AFW Custom UI Assemblies National Instruments 14
NI AFW UI Assemblies National Instruments 14
NI Assistant Framework National Instruments 14
NI Atomic PXIe Peripheral Module Driver 2.3.2 National Instruments 2.32
NI Authentication 2014 National Instruments 14
NI Certificates Deployment Support National Instruments 1.4
NI Controller Driver 1.0 National Instruments 1
NI Curl 2014 National Instruments 14
NI Error Reporting 2014 National Instruments 14
NI Error Reporting Interface 14.0 National Instruments 14
NI Ethernet Device Enumerator National Instruments 1.1
NI EulaDepot National Instruments 3.3
NI Help Assistant 2.0 National Instruments 2
NI Help Configuration Utility for VS2010 National Instruments 13
NI I/O Trace 14.0.0 National Instruments 14
NI LabVIEW 2012 Real-Time NBFifo National Instruments 12
NI LabVIEW 2012 Run-Time Engine Web Server National Instruments 12.5
NI LabVIEW 2012 SP1 Run-Time Engine Non-English Support. National Instruments 12.1
NI LabVIEW 2013 Real-Time Error Dialog National Instruments 13
NI LabVIEW 2014 Deployment Framework National Instruments 14
NI LabVIEW Broker National Instruments 6.8
NI LabVIEW C Interface National Instruments 1
NI LabVIEW Run-Time Engine 2012 SP1 f9 National Instruments 12.1
NI LabVIEW Run-Time Engine Interop 2012 SP1 National Instruments 12.1
NI LabWindows/CVI 2010 SP1 Network Variable Library National Instruments 10
NI LabWindows/CVI 2013 SP1 Code Generator National Instruments 13
NI LabWindows/CVI 2013 SP1 Low-Level Driver (Original) National Instruments 13
NI LabWindows/CVI 2013 SP1 Low-Level Driver (Updated) National Instruments 13
NI Launcher National Instruments 3.3
NI License Manager National Instruments 3.7
NI Logos 5.6 National Instruments 5.6
NI Logos XT Support National Instruments 5.6
NI MAX Remote Configuration Installer 14.0 National Instruments 14
NI MDF Support National Instruments 3.3
NI mDNS Responder 14.0.0 National Instruments 14
NI Measurement & Automation Explorer 14.0.0 National Instruments 14
NI Measurement Studio 2010 Service Pack 1 Enterprise RunTime for VS2010 National Instruments 9.1
NI Measurement Studio Common .NET Assemblies for .NET 4.0 and VS2010 National Instruments 13
NI Measurement Studio ComponentWorks 3D Graph National Instruments 8.6
NI Measurement Studio Recipe Processor National Instruments 8
NI MetaSuite Installer National Instruments 3.3
NI MXS 14.0.1 National Instruments 14.1
NI Network Browser 5.5.0 National Instruments 5.5
NI Network Discovery 14.0 National Instruments 14
NI OPC Support National Instruments 11
NI Portable Configuration 14.0.0 National Instruments 14
NI PXI Platform Framework 2.1.0 National Instruments 2.1
NI PXI Platform Services 14.0 Expert National Instruments 14
NI PXI Platform Services Configuration 14.0 National Instruments 14
NI PXI Platform Services Runtime 14.0 National Instruments 14
NI Registration Wizard National Instruments 1.3
NI Remote Provider for MAX 14.0.0 National Instruments 14
NI Remote PXI Provider for MAX 14.0.0 National Instruments 14
NI RTSI Cable Core Installer 1.5.0 National Instruments 1.5
NI RTSI PAL Device Library Installer 1.5.0 National Instruments 1.5
NI RTSI UI Provider 1.5.0 National Instruments 1.5
NI Security Update (KB 67L8LCQW) National Instruments 1
NI Service Locator 2014 National Instruments 14
NI SignalExpress 2014 Datatypes National Instruments 14
NI SignalExpress 2014 Tools National Instruments 14
NI Software Provider for MAX 14.0.0 National Instruments 14
NI SSL LabVIEW RTE 2012 SP1 Support National Instruments 12.5
NI SSL Support National Instruments 14
NI System API .NET 14.0.0 National Instruments 14
NI System API Client for WIF 14.0.0 National Instruments 14
NI System API Web-Service 32-bit 14.0.0 National Instruments 14
NI System API Windows 32-bit 14.0.0 National Instruments 14
NI System Configuration 14.0.0 LabVIEW Support National Instruments 14
NI System Configuration CVI Support 14.0.0 National Instruments 14
NI System Configuration Runtime 14.0.0 National Instruments 14
NI System Monitor 14.0 National Instruments 14
NI System State Publisher National Instruments 14
NI System Web Server 2014 National Instruments 14
NI System Web Server Base 2014 National Instruments 14
NI TDM Excel Add-In 14.0 National Instruments 14
NI TDM Streaming 14.0 National Instruments 14
NI Trace Engine National Instruments 14
NI Uninstaller National Instruments 3.3
NI Update Service 2014 National Instruments 14
NI Variable Engine 2.5.0 National Instruments 2.5
NI VC2005MSMs x86 National Instruments 8.5
NI VC2008MSMs x86 National Instruments 9
NI VC2010SP1MSMs x86 National Instruments 10
NI Visual C++ 2010 Redistributable Package National Instruments 10.1
NI Web Application Server 2014 National Instruments 14
NI Web-Based Configuration and Monitoring 14.0 National Instruments 14
NI Xalan Delay Load 1.10.3 National Instruments 1.1
NI Xerces Delay Load 2.7.6 National Instruments 2.7
NI-APAL 14.0 Error Files National Instruments 14
NI-DAQ INF Files 24.0.0 National Instruments 24
NI-DAQmx 14.0.0 National Instruments 14
NI-DAQmx 653x Installer 2.1.0 National Instruments 2.1
NI-DAQmx ADE Support 14.0.0 National Instruments 14
NI-DAQmx and NI-DAQ Common Documents 14.0.0 National Instruments 14
NI-DAQmx C and VB6 API 9.8.1 National Instruments 9.81
NI-DAQmx Common Digital 2.2.0 National Instruments 2.2
NI-DAQmx DAQ Assistant 2.9.0 National Instruments 2.9
NI-DAQmx Documentation 14.0.0 National Instruments 14
NI-DAQmx Dynamic Signal Acquisition Installer 2.8.0 National Instruments 2.8
NI-DAQmx FSL Installer 9.8.1 National Instruments 9.81
NI-DAQmx MAX Configuration Support 14.0.0 National Instruments 14
NI-DAQmx MIO Device Drivers 14.0.0 National Instruments 14
NI-DAQmx MX Expert Framework 14.0.0 National Instruments 14
NI-DAQmx SCXI 2.2.0 National Instruments 2.2
NI-DAQmx STC 1.13.0 National Instruments 1.13
NI-DAQmx support for LabVIEW 14.0.0 National Instruments 14
NI-DAQmx Switch Core 14.0.0 National Instruments 14
NI-DAQmx Timing Installer 2.9.0 National Instruments 2.9
NI-DAQmx/LabVIEW shared documentation 14.0.0 National Instruments 14
NI-DIM 3.1.0f0 National Instruments 3.1
NI-MDBG 3.1.0f0 National Instruments 3.1
NI-MRU 3.1.0f0 National Instruments 3.1
NI-MXDF 3.1.0f0 National Instruments 3.1
NI-MXLC Core (32-bit) National Instruments 14
NI-MXLC LabVIEW 2011 Support National Instruments 14
NI-MXLC LabVIEW 2012 Support National Instruments 14
NI-MXLC LabVIEW 2013 Support National Instruments 14
NI-MXLC LabVIEW 2014 Support National Instruments 14
NI-ORB 3.1 National Instruments 3.1
NI-PAL 14.0 Error Files National Instruments 14
NI-PAL 14.0.0f0 National Instruments 14
NI-RPC 14.0.0f0 National Instruments 14
NI-RPC 14.0.0f0 for Phar Lap ETS National Instruments 14
14
Reset NI Config 14.0.0 National Instruments 14
WIF Core Dependencies Windows 14.0.0 National Instruments 14
(12,109 Views)
NI has a chart here that shows the compatibility of LabVIEW and its components with Windows OS versions.  You should be "mainly OK" for Windows 7, but may want to consider updating for Windows 10.  Talk to your NI Sales Rep or NI Support.
Bob Schor
(12,083 Views)
Thanks Bob,
Can you confirm all the above installs are in relation just to Labview?  Or are they part of other NI application install?
(12,048 Views)
Some of them I don't recognize, probably because I have not installed every Toolbox and Module that ships with LabVIEW (my typical install is LabVIEW + LabVIEW RT + Vision, along with Drivers for DAQmx, VISA, PXI, and Vision).  I've never used LabWindows nor most other hardware Toolkits.  However, it does make sense to me that all of these are part of the NI Software Installation, and all were installed by one or more "LabVIEW Installation Kits".  In particular, if you go into Control Panel, Programs and Features, NI Software, and choose "Remove All", I would expect all of them to be uninstalled (and the process, given the number you have, to take at least an hour).
Bob Schor
(12,036 Views)
Thanks Bob, i thought that might be the case but as these machines are in the production environment removing is not an option at present and as always no documentation!!
(12,028 Views)
