Software Runtime Errors present on Machine
We are currently running Windows XP with Labview 6.1. We are getting errors while running the software related to database errors. They happened over the period of multiple days after loading the software on Windows XP. Attached are screenshots of these errors as we recieved them. We are currently looking for solutions to these errors and any assistance would be appriciated. Thanks in advance.
(3,198 Views)
Hope this thread will tell you why you are getting database error.
(3,187 Views)
I can't find the logos.ini file that is pointed out in that fourm topic. It does not seem to be present. Also to note we are running Windows XP on this system. We are running logos 4.4 already on this system.
(3,168 Views)
Hi Corey,
If the file is not there, try creating it.  You will need to place it in the C:\WINDOWS\System32.  You can refer to this document and it's related links for more assistance.  It's not updated with info for Windows XP, but it should still apply the same way.  If this doesn't work, then definitely take a look at the related links for more help:
http://digital.ni.com/public.nsf/allkb/862567530005F09E862567C700746A65?OpenDocument
(3,126 Views)
