Software based pulse generation for digital output
I want to output a digital pulse on my USB 6501. Since this hardware doesn't have a counter/timer built in, I have to use a software based apporach to generate pulses. How can I generate a digital pulse to a specific digital line given N samples, and a specific amount of high and low time (ex: 50ms).
Until now I have been using the Express VI / DAQ Assist to communicate with USB 6501. Express VI / DAQ Assist doesn't give me an option to gerenate pulses to a specic line using software timer.
Attached is my apporached to create software pulses. However, I am pretty sure my method inefficent. It would be great if someone can show me on to improve my code.
(4,651 Views)
Hi aab,
an excellent starting point are the example VIs coming with LabVIEW. Did you examine them?
(4,608 Views)
Yes I looked through examples, however, I don't think I was able to find somehting
(4,582 Views)
Hi aab,
in the Example Finder you can limit the shown results to your specific hardware.
So search for example VIs compatible with your USB6501 and you will see two examples for generation of DigitalOutput signals…
(4,573 Views)
I didn't find an example for software timed pulses at digital output. However, I modifed the example for "Digital- SW-Timed Output.vi". I modified this VI to create my own software timed pulses. It works. However, it would be great if someone can confirm if I am using the correct efficent apporach generate the software timed pulses.
See attached.
(4,556 Views)
