Software communication data serial with mitutoyo micrometer
I decided to create this topic so that I can help someone who is in need. It was a very difficult to decipher the serial data communication continuously from the instrument. For further questions follow my contact clovis.belcari@gmail.com. I hope it helps someone.
Instrument: Micrometer serie 164-164 Mitutoyo
LabView v. 2011
(2,796 Views)
Accepted by topic author belcari_brazil
Hi belcari,
some notes:
  • Don't use BMP as image format, use PNG (or JPG) instead for much smaller files! (See attached converted images.)
  • Don't use BytesAtPort for serial communication, especially for devices using a TermChar!
  • Why do you need VISAWrite 3 times just to send 3 bytes to your device?
  • That "string to numeric" conversion is probably much easier when you use ScanFromString with the right format string…
  • Why is "Update Time" a DBL, when the wait expects an integer value?
  • You don't need to set default values at SerialPortInit…
(2,769 Views)
Thanks for your help my friend!!!
(2,760 Views)
