Software-controlled VI appearance.
Hello !
Is it possible to controle VI appearance depending on paramters passed to it ? Let me be more precise : a VI is called passing an integer, reflecting a certain mode of use. In mode "0" the windows of the VI is opened and appears at the low right corner of the screen. In mode "1" it appears at the low left corner. While in mode "2" the windows does not appear at all. To my greatest shame (I am an autodidact Labview user ...) I am so far using 3 differents VIs, each saved with the required preferences. But it is not very elegant one would argue ... I would like either being able to controle the pop-up of the execution windows from within this VI or, if not possible, from the VI calling it.
Thank you very much for your help.
Nico
PS : an example code would be most welcomed as it is sometimes difficult for me to figure out what to do just reading answers using concepts I am far from mastering. Thank you again.
(3,110 Views)
Hi gritche
see the attachement. I use this vi to change the title or the position and size of it. Every other property is also possible.
Mike
(3,107 Views)
Thank you very much for your prompt reply, but I have a small problem : I am currently running 8.2 version of Labview while you appear to use the 8.5 one. I am unable to open your example code for that reason. Can you save it under 8.2 format ?
Thank you !
Nico
(3,086 Views)
Hi
now the 8.2 Version
Mike
(3,084 Views)
