Software defined radio, adalm-pluto
Wondering if anyone has built an interface for the Analog Devices software defined radio, "Adalm-pluto"
https://www.analog.com/en/design-center/evaluation-hardware-and-software/evaluation-boards-kits/adalm-pluto....
Message 1 of 10
(7,590 Views)
That looks interesting, It says it has...
MATLAB®, Simulink® support
GNU Radio sink and source blocks
libiio, a C, C++, C#, and Python API
I would think that means you could in theory write some sort LabVIEW wrapper the uses the  C, C++ or C# libraries.
=== Engineer Ambiguously ===
Message 2 of 10
(7,562 Views)
There are a few 2016 and 2013 era postings on this forum about the TV dongle SDR device that tell a similar story.  Something about making a vi that wraps around a windows .DLL file - maybe folded into a VIPM package.
Reference, https://forums.ni.com/t5/Example-Program-Drafts/Using-RTL-SDR-with-Labview-Chapter-1-Labview-on-Wind...
The package is no longer listed though and "wrapping a dll" is something I've never done.  Is there a basic how to that describes how to interface with external to labview programs?  Is this the standard approach?  https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGZjCAO&l=en-US
Message 3 of 10
(7,558 Views)
Or, related, how do you interface with a C++ library in a LabVIEW module?
https://github.com/pothosware/SoapySDR/wiki
Message 4 of 10
(7,552 Views)
BTW: I believe LabVIEW NXG has a Python node
So you may want to look into using that.
Message 5 of 10
(7,549 Views)
Thanks for the pointer!  LabVIEW 2018 does have Python node.  This will be easier that rolling my own DLL!
Message 6 of 10
(7,534 Views)
would you happen to have an example of what you did with the python node?
Message 7 of 10
(6,369 Views)
Apologies, not yet.
Message 8 of 10
(6,364 Views)
Were you able to come up with an example of the python node and adalm-pluto?
Message 9 of 10
(2,632 Views)
Hi. Just wondering if you could figure out the answer ....
Message 10 of 10
(2,390 Views)
