Solenoid Valve with Labview
Hey everyone,
Im brand new to LabView and I am in need of some assitance. Ive attached a picture of my block diagram setup. I need help with making the LabView code in order to help run this setup. I want to use LabView to activate my photoelectric sesnor, which when tripped will activate my solenoid valve immediately. The maximum allowable time between the photoelctric sensor being tripped to the valve opening cannot be greater than 50 milliseconds. I would also like to active my high speed camera 1 second prior to the electric sensor being activated. I have included the parts I am using in a list below. Thanks for all the help in advance.
Solenoid Valve: SV-282 from Omega
Photoelectric Sensor: Comet 14101A6517
Output cDAQ: NI-9472 (powered by external power supply "NI PS-15 24V")
Input cDAQ: NI-9421
Camera: Phantom v7.3 (connected through ethernet)
In summary: with labview, activate camera, activate photo sensor which when tripped will open solenoid valve immediately.
Shervin Aslani
(5,235 Views)
Since you're brand new to LabVIEW, you are probably going to want to start at this link to get more familiar:
http://www.ni.com/gettingstarted/labviewbasics/
Have you written any code to start out with? If you have, you can post it up and perhaps someone on the forum might have advice for you on it.  This link might also be good since you will be interfacing with hardware:
http://www.ni.com/white-paper/2835/en/
Mason M
(5,160 Views)
You're at the fun stage of the project!  You can start to write instrument drivers while (at the same time) learning how to program a state machine. 🙂
I LOVE starting projects 😄  I hate the tedium of finishing them... until they're done, then I love it again.
Jim
(5,146 Views)
Duplicate post.  Being handled here:  http://forums.ni.com/t5/LabVIEW/Solenoid-Control-with-LabVIEW/td-p/2509754/page/2
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(5,129 Views)
