SolidWorks/COSMOSMotion을 통한 예제를 실항하던도중 Open Straight Line Move Handle.vi 라는 에러 발생합니다.
DAQmx를 이용한 ATI F/T센서와 SolidWorks를 연동 하고자 LabVIEW-SolidWorks Mechatronics Toolkit의 예제를 실행하던 도중 Open Straight Line Move Handle.vi 라는 에러 메지시가 발생합니다. ATI F/T센서 프로그램을 사용하기 전에는 예제가 실행이 되었는데 ATI에서 제공하는 ATI DAQ FT Demo.exe를 설치할때 DAQ관련 디바이스드라이버를 깔고나서 부터 되지를 않네요; Uninstall을 하고 재설치도 해봤는데 예제가 실행이 안되네요.
부탁드립니다.
seohojin
(3,253 Views)
Korean to English
DAQmx with ATI F / T sensors and SolidWorks LabVIEW-SolidWorks Mechatronics Toolkit want to work together to run the examples were called during the Open Straight Line Move Handle.vi Mejiro cigar errors occur. ATI F / T sensor before using the example program will run from ATI easier to provide ATI DAQ FT Demo.exe seolchihalttae DAQ related to the device driver does not see a down since then; Uninstall, reinstall the examples I've run is No way.
Appreciated.
(3,238 Views)
Hello Tiger,
If possible can you please post a proper translation of your question in English?  If not, I would suggest contacting the National Instruments branch in Korea with your question, as there is no Korean forum. Here is their phone number: +82 02 3451 3400. I hope this helps.
Best Regards,
Brooks
(3,223 Views)
