Solidworks model mating issue in 3D Picture control
Here is 2009 file.
P.S. Also cross pasted here
Thanks & Regards,
Kunal Raithatha.
CTD - CLAD (I wish I can take off that A, and maybe use it later to replace D 🙂
Easy Tip :- "To copy an image to a VI icon, drag the image file and place it on the icon
located in the upper right corner of the front panel or block diagram" ...If you know any
more reply back.
Message 11 of 16
(1,145 Views)
Zoom Object Only
Thanks & Regards,
Kunal Raithatha.
more reply back.
Message 12 of 16
(1,142 Views)
These latest questions are also answered on another site.
Zach C.
Field Engineer
Greater Los Angeles
Message 13 of 16
(1,128 Views)
Zach
I still need to figure out issue with 2009 VI I uploded before this.
Thanks & Regards,
Kunal Raithatha.
more reply back.
Message 14 of 16
(1,124 Views)
What is the question you have with the 2009 file?
Zach C.
Field Engineer
Greater Los Angeles
Message 15 of 16
(1,111 Views)
Kunal,
I found a great example that should answer your questions about how to get the correct movement between joints.  It is the 3D Animated Hand example posted on the community.  You will notice that it combines multiple objects together and performs rotations on the combined objects.
Zach C.
Field Engineer
Greater Los Angeles
Message 16 of 16
(1,091 Views)
