Solve a nonliear equation with external inputs?
A nonlinear system is depicted as follows:
x = 2*a-b+w-2*m;
y = b-a+m-w;
z = 2*a+b-2*m-w;
x*z^3/(m*w)-kp1 = 0;
y*z/(x*w)-kp2 = 0;
where the parameters a,b kp1,and kp2 are inputs, the parameters m and w are outputs.
We want to solve the last two equations with the "nonlinear equation solvers" to setup the model relating the inputs and outputs.
How can I build the VI?
I tried to enter the equations refering to "Equation Explorer Example.vi", but it can not work with inputs variable.
I also tried to build the equations with "concatanent string",etc., but it is rather a tedious works even to make a simple equation.
Thanks in advance.
Dongbin
(3,357 Views)
Hello Dongbin,
I created an example program which I hope is what you are looking for. You may need to modify the "Start" and "End" matrices as you see fit, but the important part is how I got the string arrays formatted for the Nonlinear Equation Solver.
I hope this helps! Happy Holidays!
Liz Fausak
(3,357 Views)
Hi Liz,thanks for the example! I tried to write a subvi to solve an nonlinear equation using the example, however it never give a solutions! Would you please take a look at my vi and give any hints?
Many thanks!
Camu
(3,000 Views)
