Solve differential equation with measurement results
Hello everybody,
I would like to solve a (simple) differential equation:
y ' (x)  +  p * y (x)  =  q(x)
The special issue with my problem is that  q(x)  is given as measurement data (e.g. array of numerical data). A numerical solution of y(x) would be sufficient for me. Unfortunately, I couldn't find any solution yet. Any help would be appreciated.
Thanks a lot in advance
Best regards
(2,355 Views)
The best way probably is to use the Control Design and Simulation Module. There is an webcast to be found here youtube under: Solving a differential equation on LabVIEW  and a lot of documentation over the web.
http://www.ni.com/white-paper/5855/en/
www.youtube.com/watch?v=rQ-H73iTe3g
Onother way would be to use the Euler or Runge Kutta calcation, included in LabVIEW Full.
http://zone.ni.com/reference/en-XX/help/371361J-01/gmath/ode_euler_method/
(2,314 Views)
