Solving error -52005
Dear all,
I use Labview2010 to access a Spartan3 Xilinx FPGA, and tried to give it a simple VHDL code with the IP integration node.
During compilation I got the error -52005, and found this solution:
http://digital.ni.com/public.nsf/allkb/8A49034C699AA6FF862577D2007D9970
The problem is that when I open MAX, spot "Software", then "Add/remove software", then I end up with a list of NI softwares (look at the attached screenshot), as you can see, I can only change, repare or remove the programs, but I don´t see where I can add one.
Does anyone see where I got wrong ?
Thanks in advance,
regards
(5,917 Views)
Hi Ksawery,
what driver is installed and what hardware is in use?
Have you tried to install a newer NI-RIO driver?
The KB you found is for cRIO devices on this you can install the Scan Engine
 Additional have you tried to compile only a vi with a While loop inside?
best regards
Alexander
(5,893 Views)
Thanks for your prompt answer, I have installed the following patches and drivers (each one requiring the next...):
1. LabVIEW 2011 SP1 (32-bit) German!!
2. (LabVIEW 2011 SP1 f1 32-bit Patch)
3. LabVIEW FPGA Module 2011 SP1    (need to rename the exe into a zip file. to extract)
4. NI Digital Electronics FPGA Board Driver Software 4.3
5. installing Microsoft USB Hotfix WindowsXP-KB969238-x86-DEU.exe
And I changed for LabView 2011 instead of 2010. I still don´t have the possibility to add a software using MAX, but I don´t get the Error -52005.
Instead I get the following when compiling & loading my VHDL code to the FPGA:
Error Code -310611 in niFpgaOpenAndRun_DE FPGA Board.vi
Possible source:
NI-COBS: An internal software error has occurred
I could not find any related past threads, and even Google itself remains still.
Do you have an idea ?
Ks.
(5,879 Views)
We found out, a bit by chance: using the NI-License manager, we re-registered our product and the problems mentioned above disapeared.
Thanks a lot for your support !
Ks.
(5,863 Views)
