Some Doubts in write into spreadsheet file function
hi,
i have some problem with writing the values into excel file...if \ found then the values after will write the values in next rows...
for eg. if i give 78/58\46/86 then i will write as in picture i hav attached..
(2,507 Views)
The Write to Spreadsheet File is not the same as writing to Excel -- for that, you should use the Report Generation Toolkit (and there have been a number of posts here, as well as examples that ship with LabVIEW).
That being said, it is not clear (a) what you are trying to do, and (b) what is (or is not) happening.  The image you attached looks OK ...
(2,438 Views)
