Some Fundamental Knowledge on TCP
Hi, all I am pretty new to Labview and would like to ask two questions
about Labview TCP.
(i) For TCP/IP in other language, like using socket, there is no
gurantee of data arrival in 1 packet. In another words, we usually
send the size as a hearder in the packet and keep receiving until we
reach the "size". I am wondering if this is the same case in TCP in
Labview?
(ii) after establishing successful connection. I am able to send
message from the labview side to the VB server. However, I just don't
seem to find a way to tell if data are pending. In another words, how
can I tell if someone has sent a packet to Labview so that I can do
TCP Read.
Thanks in advance.
Alan
(2,782 Views)
(i) Yes, same with LV.
(ii) You'll need to do a read. The read has a timeout input so you can do a 0 second timeout if you want.
(2,782 Views)
Thanks very much for your information.
(2,782 Views)
