Some minor tips
Well, you may already know these but here are a few things I have found
useful.
I work on Unix boxes so these may work differently for you.
Meta may mean ALT (PC) , or that funny little key on the Mac
To Kill a runaway VI. - Meta .
In descriptions you can make Bold characters by using
HTML tags for bold i.e. put < B > and < /B > around the characters.
(Remove the spaces).
In the Hierarchy Window type the first letter of the VI name
(case sensitive in UNIX, not sure about others). This will find
the first VI that starts with that character. The arrow keys will
move around to the next match.
Remove redundant wires - Meta B
This removes redundant as well as bad wires.
(Bad Wire ! Bad, Bad Wire !!)
May your wires be straight and
true.
Kevin Kent
Message 1 of 1
(3,184 Views)
