Some problem when create EXE
I just create a project and it can be running successfully in compile environment,but after create EXE, it cannot run,i don not know what happend.I used ZeroMQ. Error 13 occurred at Call Library Function Node in zeromq.lvlib:zmq_context.lvclass:zmq_ctx_create.vi:5610006->RunStep.vi:4260001->Executor.lvlib:Executor.lvclass:Execute.vi:6020001->Executor.lvlib:Executor.lvclass:Execute test vi.vi:4350001->Executor.lvlib:Execute test vi Msg.lvclass:Do.vi:3750001->Actor Framework.lvlib:Actor.lvclass:Receive Message.vi:1040002->Actor Framework.lvlib:Actor.lvclass:Actor Core.vi:5880002->Executor.lvlib:Executor.lvclass:Actor Core.vi:5880001->Actor Framework.lvlib:Actor.lvclass:Actor.vi:6640009->Actor Framework.lvlib:Actor.lvclass:Actor.vi.ACBRProxyCaller.93000000 Possible reason(s): LabVIEW: Failed to load dynamic library because of missing external symbols or dependencies, or because of an invalid file format. ========================= Shareable board exclusively owned.
(1,513 Views)
It seems you haven't included some libraries on your executable. Please check whether you included everything.
(1,458 Views)
