Some questions on application builder.
Usually I use the labview application builder to create stand alone applications to run on other PCs in our office. The builder fitted all my previous projects in one exe file.
My last project uses labview classes with virtual inheritance and application builder creates additional folders with virtual VIs. Is there any way to fit everything in one exe file? I am a little confused. My virtual VIs call dependencies from vi.lib or instr.lib but there are no dependencies stored in built folder. What happens if I run this application on another PC which doesn't have installed labview and so doesn't have vi libraries?
Think you.
(2,657 Views)
Alex,
there is already a thread answering your question here
It's message 24 within the linked thread.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,648 Views)
Norbert B,
Thank you.
(2,635 Views)
