Somebody worked with HP3458A?
There is a problem with the module "Read Digital Sample Memory.vi". At check of ERROR on a computer is not present. But here HP gives the message on a ERROR. A line of the reference such "END ON;RMEM 1,100;". Other installations standard. Why it occurs?
(2,867 Views)
I haven't worked with this particular instrument, but I looked into the instrument driver and I can't figure out exactly what you are asking.
I checked the "HP 3458A Read Digital Sample Memory.vi". It does send as you mention the "END ON;RMEM 1,100;" command. The VI does not check for error conditions in the instrument. You can use the utility function "HP 3458A Utility Error Query.vi" to ask the instrument if any errors occurred.
Is the instrument giving an error?. What error is it?
DiegoF
National Instruments.
(2,867 Views)
