Something about charts
In my aplication a need to view a data in order to time, but when i
start running the aplication all the datas in the charts must be zero
(chart clean). I only do this with a chart. Something help me who i put
dats in order to time, for instant, in a chart?
Thanks for your atention?
Paulo Cardoso
(2,754 Views)
I'm not totally sure that I understand your question, but let me take a shot.
You want to clear the chart every time you before you run the operation?
You can do this using a property node. You have to use the history property. You have to write an empty array into it.
Attached is a small example.
Hopefully this will help a little..
(2,754 Views)
