Sorensen XG 60-14 error
Actually, the IVI drivers and the LabVIEW code from RSTLVU, all use VISA to send SCPI commands. IVI makes for interchanging instruments without modifying the application programming. VISA makes for interchanging physical interfaces without changing driver code. SCPI makes instrument commands more readable and generalized.
Message 31 of 33
(719 Views)
And, the OP was merely writing that had the suggested solution of closing all the References not work - which worked for him since his software ran for a week without issues,
then he was going to make use of RSTLVU's VIs as plan B.
Message 32 of 33
(717 Views)
Thanks for the explanations! I think it is getting more clear 🙂 it is just so easy to create a kind of (mis)understanding in my mind based on partial knowledge on all these driver/programming details 🙂
Message 33 of 33
(689 Views)
