Sort Menu Ring text
Is there a way to sort the Menu Ring text? If there is, where is it located?
(3,904 Views)
Accepted by topic author Eric1977
You can do it programmatically using property nodes like this.
(3,889 Views)
Thank you, Jimmy. Pretty easy solution.
(3,880 Views)
