Sort a string into an array HELP
I think not, I think I mean the array type thing ion the bottom left with the zeros in it, what is that?
Message 11 of 28
(2,413 Views)
no wait, you were right
thanks
Message 12 of 28
(2,412 Views)
By the way,  if you have LabVIEW 9 and are using Internet Explorer, you can simply drag the image (code) that i posted to your block diagram and it will automatically create the code.
Will you always have "N" and "E"?  Since these appear to be coordinates, would you also need to deal with "S" & "W"?
Message 13 of 28
(2,400 Views)
No this is not the case. The N is just to confirm that the measurement was taken correctly and the E is the exponent thingy, you know in scientific notation 1e3 = 1000 sort of thing.
On the other hand they will always be there.
Once i've got a code written, which won't be after the weekend, so you think I could post it here for someone to take a look at to see if it could be made a little simpler? Or more efficient etc....
Message 14 of 28
(2,385 Views)
@Pazmush wrote:
Once i've got a code written, which won't be after the weekend, so you think I could post it here ....
Yes.
- tbob
Inventor of the WORM Global
Message 15 of 28
(2,377 Views)
It's a good idea.
Sorry for being confused.  I didn't know what the 'N' stood for.
Message 16 of 28
(2,350 Views)
Here is what I have done so far, What I need to be able to do now really is stick all these arrays into some sort of table and write them all to one spreadsheet file but I can't figure out how to do tables?? Also is this the best way to do what I want?
Message 17 of 28
(2,331 Views)
18645i9B115E4B2CB11FCF
Message 18 of 28
(2,329 Views)
Try something like this:
Message 19 of 28
(2,316 Views)
What is the fuction you are using and is that a better way of doing it?
Also can anyone help with the table thingy problem?
Message 20 of 28
(2,311 Views)
