Sorting 2D array using formula node
You need to go to your specific message that you marked as the solution.  That is the one that will have the "Unmark" within its option menu.
You shouldn't have marked your response as the solution.  You should have gone to his message and clicked the solution button.  You'll get that choice back once you unmark the specific message you already marked as the solution.
Message 11 of 11
(631 Views)
