Sorting a Table
Hmmm
I'm confused.  Supposedly, if you interpret the 64 bits of a double FP as a 64-bit signed integer, it will sort correctly.
But I observe this:
What am I missing?
Message 31 of 36
(1,283 Views)
I haven't studies it in detail, but it might have to do with the fact that negative integers are in Two's complement.
Message 32 of 36
(1,275 Views)
In both Double, and I64, the MSB is 1 for negative, 0 for positive.
Message 33 of 36
(1,263 Views)
I was talking about the remaining bits, which are in two-s complement for negative numbers.
For example in l8,
1 = b00000001
-1 = b11111111 (i.e. not b10000001)
Message 34 of 36
(1,243 Views)
For example in l8,
1 = b00000001
Sure.  But I believed (and have read) that interpreting an (IEEE 754) floating point number as a (two's complement) signed integer would result in the same ordering as interpreting the floating point value.
Message 35 of 36
(1,191 Views)
OK, I'll take another stab at this.  I fixed the numeric sorting, and added a new mode (Hierarchal).
It occurred to me that there may be a need to sort things such as paragraph identifiers that typically use hierarchal numbering: "1.1" < "1.10".
However instead of using a "Mode" input, I made a polymorphic VI.
Message 36 of 36
(1,186 Views)
