Sound File Read and Express Play WaveForm.
Hi, all
I am trying to control the volume on the Play WaveForm express vi, but have not been able to make this happen. Does any one have suggestions that I can run with.
Thank you.
(2,749 Views)
I have found two examples of an Audio Equalizer that controls a sound output. The first is simplified version of the second. I hope this helps!
Audio Equalizer (simplified): https://decibel.ni.com/content/docs/DOC-8435
Audio Equalizer (advanced): https://decibel.ni.com/content/docs/DOC-16037
Jason D
(2,725 Views)
