Sound File w/ Boolean
    What i'm trying to do is have a sound file play as an alarm in my program rather than just a beep. When the result of my program is True the alarm will go off. I can get it to work with the beep.vi but I was wondering if there is a way to play a file with boolean. Or if there is any other way this can be accomplished?
(6,355 Views)
Checkout the example:  Interactive Play Sound File.vi
When run it plays a wav file.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(6,351 Views)
There is a play file function under the Graphics & Sound/Sound/Output palette.  Feed the path to the desired wave file into there.  Put that inside the case structure.
Message Edited by Ravens Fan on 05-24-2007 10:23 PM
(6,351 Views)
I leave an example that can provide, use it in your program
(5,990 Views)
What are you doing???  No offence but you're not helping anyone here by clogging the forum with responses to outdated threads all on the same subject.  Plus, you really should get some more LabVIEW experience before you offer examples. Smiley Wink
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(5,977 Views)
Your example is not reading the wav files that you provide.
(5,227 Views)
CSAGroup,
     After being a member of the LabVIEW Community for 4 years, this is your first post.  Congratulations.  But it is a strange comment on a very old post whose origins are a decade and many versions of LabVIEW ago.
     Resurrecting old threads like this is not helpful to the Community.  For your second post, consider starting a new thread (or "New Message") and if you need help with something, state the problem clearly, provide LabVIEW code (VIs are best) the demonstrates the problem, and let the Community respond.  The clearer and more relevant the Question, the more likely you are to get a helpful Response.
Bob Schor
P.S. -- please do not continue this thread.  Start a new one.
(5,215 Views)
