Sound Input using Sigmatel Audio 9200
Hi, I'm using the "Sound Input Read.vi" to aquire a analog signal from the Sigmatel Audio 9200 input. I'm using a Kistler Charge Calibrator to generate a square Waveform (0,5Vpp). When I measure the signal with a osciloscope, I can see a perfect square waveform. But, when I run the VI, I can't see the perfect waveform. I thought that the problem was happening cause I used a stereo cable, but I changed it to a mono cable and the problem continued happening.
Has somebody any suggestion?
(3,461 Views)
 What do you mean by "can't see the perfect waveform"? Is it exists?Is it noisy?
What is it freq? What is the sampling rate of the sound card?
Michael
_________________________________________________________________________________________________
LV 8.2 at Windows & Linux
(3,453 Views)
At the attachment you can find the wrong waveform that I can aquire. The frequence is 27,7 Hz.
(3,441 Views)
Datasheet of the soundcard:
http://www.idt.com/?genID=STAC9200&source=products_genericPart_STAC9200
it's written there that the lower limit is 20 Hz.If it is about a sine wave,than probably your square wave has too low
freq. for this card.I would try to rize the freq. and see if the picture goes beter.
Michael
(3,430 Views)
