Sound Input w/ Queue Status gives error 4822
hey
i have a simple queue based state machine that is reading and writing audio in a loop. (i have included a png of the main part). this runs fine using the Labview 7 VIs (which give no control over no. of samples read), but i initially tried doing this with the Labview 8.2 Sound VIs, but the code would never run. i cannot understand why. can anyone enlighten?
the loop would execute once or twice (or occasionally for about a minute, very rarely) then quit with error 4822, for which i can find no info. if i remove the queue status VI from the loop, then everything works as expected.
any thoughts?
(4,878 Views)
Hi Kreuters
I have had a look at the screenshot of your code and everything seems to be ok, would it be possible for you to post your code on the thread and that way I can try and replicate your issue at this end.
The 4822 error code seems to be a timeout error,
Look forward to your reply
YatinM
NIUK & Ireland
(4,847 Views)
hey there
having a few problems writing you some example code at the moment, as the current machine i am using, the new sound functions will not even recognise any of the 3 soundcards attached to the computer (old functions still work fine).
i will be back on the machine i originally had the problem with tomorrow, will send some code then,
(4,841 Views)
