Sound Level Meter vi
It would be great if I could manage to have a Sound Level Meter vi. I do not have SVT.
Right now a .vi sharing would be best, but in my mind it is to start to make my own, this kind of tasks make you learn. The problem is time.
Any sharings? Suggestions? I found this in an old post, but, I get this error:
"Poly VI 'AI Acquire Waveform.vi': subVI is missing.
(4,224 Views)
Bump
I am also looking to do the same thing
(3,759 Views)
AI Acquire Waveform is part of the old traditional DAQ API.  You can either replace the traditional DAQ VIs with DAQmx VIs or install traditional DAQ (provided you are on a supported, 32-bit OS).  I would recommend the former.  The sound level algorithms should still be good.  Let us know if you run into issues.
(3,746 Views)
