03-07-2007 12:37 PM
Hello
I’m building a VI with DAQmx - USB 6008, for measurement of sound. The current program is only a simulation for the measurement, and the idea of the design is to transmit the sound level signal into ‘colour fill tanks’ indicators on the front panel, for the viewer to see.
The difficulty I have is:
How do I connect ’fill tanks’ indicators – conditionally – to an output of a sound measurement VI?
The idea is to limit each ‘tank’ indicator to a level of sound, in such a way that the viewer sees visually the level of the sound on the front panel in those ‘filled tanks’.
When the level of the sound is for example from a to b the signal is send into the first ‘tank’ indicator. When the level is from b to c the signal is send to the next ‘tank’ indicator and so on…
My problem is how to wire the signal -conditionally with
The program is running well otherwise.
I attach the VI, and a detailed explanation of the VI in a Word file.
Anyone has a god idea how to solve it?
Thanks for your help.
Iris
03-08-2007 05:50 AM
03-08-2007 07:50 AM
To Dennis Hej
Thanks for your help. I will look at the adds (corrections) you made.
Thank you
Iris
