12-09-2008 05:17 AM
12-09-2008 08:44 AM
12-11-2008 03:30 AM
Hi
Is there any chance you could post your VI? It can be quite helpful to see exactly what is going on the code. Also, what hardware are you using to control the output level and what version of LabVIEW are you using? If you let me know then I'll be able to take a more in-depth look into the issue. Looking forward to hearing from you,
Best Regards
12-11-2008 04:22 AM - edited 12-11-2008 04:31 AM
The sound system behaves much like files. The sound Task ID is the same as a file refnum. Anyway i think it is solved now
EDIT
Oops found a smal bug in the case handling the meter event. Change the output to NewV
al
12-12-2008 03:24 AM
Hi Guys thanks for the replys. I am using Labview 8.2 and am taking in a analog signal via the NI USB 6009 Board. Attached is the code I have been working on - I hope you can shed a little light on this problem for me!
Cheers
Greg
12-17-2008 10:23 AM
Hi Greg
I've been taking a look at the issue, but without being able to run the VI, I've been unable to find any obvious solution to the problem. Is there any chance you could also post the subVIs? They are named 'Analog Input (1 sample).vi' and 'Sound File Input.vi'. If I have these then I can run the VI and experiment with a thing or two.
Looking forward to hearing back from you,
